Re: wd45 brakes
Author |
Denny
08-20-2002 09:31:40
It is a tough job. The toughest part is getting those infernal pins out of the bottom of the casting that hold the bottom of the bands. I worked on my D-17 (has same system) for two weekends before giving up. I've heard that drilling and tapping the pin is the only solution. A guy once told me about 7 years ago that he got one side done on his D-17 for $250. Good luck,
Tom
08-20-2002 17:50:37
Re: Re: wd45 brakes in reply to Denny, 08-20-2002 09:31:40
Yes, drilling and tapping works, but to do it there are a few things you need to be aware of. Drill for a 3/3-24 tap, use a new tap. the pins are case hardened, grind up to 1/16 off the end. Centerpunch as close to center as possible. Drill as straight as you can, have someone help by sighting the drill as you go. Use a small drill moter to help you get the drill up in proper alignment. Take off the wheel and tire to get room to work easier. Use a lot of cutting oil on the (new and sharp) tap, you don't want to break lit. Use a grade 8 or better capscrew or threaded rod, it can take a lot to get these pins out. Drill and tap deep enough to get 1/2 " of threads in past the neck in the pin, you can pull the end of the pin off, the neck isn't very strong when you get a 3/8 : thread in it. It won't weaken the pin, they go through a lot of casting before the breaks. If you get the pins out without this or if you use new pins, have someone with a lathe drill and tap them nice and straight before you put them in, you or someone else will thankyou someday. Fill the hole in with a capscrew to keep it clean and rust free. Put grease in the hole in the casting before putting the pins back in. Pounding the pins IN and twisting them with a visegrip can work but maybe not too. These pins can be a bitc* but you will only have to do the job once if you grase them and they are drilled and tapped when you put them back in.
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Women and Tractors - More Views From the Farmer's Wife - by Teri Burkholder. The top ten reasons why the judges wouldn't let you participate in the stock antique tractor pull: Hey, this is stock! It came with that V8 in it! That "R" on my tires stands for "really old" not radial! Blue gas? We thought it was a pretty color! What wire hooked to my throttle?
... [Read Article]
Latest Ad:
A pair of 11x38 drop center rims off of an Oliver 77, super nice originals, never had fluid in them, can send pictures,calls only
[More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
