Re: Allis-chalmers WD
Jim (Mi)
08-13-2002 09:39:29
Congratulations, you have just experienced probably the only bad thing about the tractor. Their is really nothing you can do. I had my whole system rebuilt thinking that it was supposed to work like my father-in-law's Farmall. What i do on my WD is their is an exact and I mean exact position once you have it at the desired level that the lever needs to be in to stay put. I then clamp on a small bar clamp to the quadrant not allowing the lever to move. Good Luck.
Farmer Brown
08-29-2002 20:14:29
 Re: Re: Allis-chalmers WD in reply to Jim (Mi), 08-13-2002 09:39:29
If the hydraulics will not hold even with controls set in the hold position, you might need to replace the hold valve seat. Early WD had a seat that was not hardened and could peen out. Later models had a hardened seat which is what the repair part is. We had 3 WD's, one would not hold at all and the other two would. The one that would not was a '49.
