Company Logo (800) 853-2651 Shop Now
Re: WD hand clutch broken
Harold
08-12-2002 12:51:17
If your linkage is all ok it probably needs adjusting. This is done by removing brass shims. There are three sets of shims.Usually remove about two to three shims out of each set. First remove battery box then remove clutch cover. Then loosen bolts in clutch assembly & remove shims. With clutch disengaged you need .30 Thou clearance. Hope this helps
Today's Featured Article - Harry Ferguson - The Man & The Machine Harry Ferguson was christened Henry George but every one called him Harry. Harry was born in a small Irish town called Growell in County Down about 16 miles from Belfast. Harry Ferguson led a varied and colorful childhood causing mischief where ever he could. He showed mechanical aptitude at a very early stage in life and showed no inclination towards ... [Read Article]
Latest Ad: Need one ,castiron, screw-on hub cap. for a JI Case 8 foot grain drill [More Ads]
