Re: WD45 Throttle ????
JMS/MN
08-10-2002 17:23:52
Follow the throttle shaft down to below the gas tank and you will find a half-moon shaped device, then later a pivot and a swivel with a set screw holding the rod that goes to the governor. Loosen the set screw and adjust the rod into the proper position. Full speed of the engine is slightly less than full travel on the quadrant by the steering wheel. As to maintaining position, are the hard rubber blocks still on your levers for hydraulic and speed control? Their resistance against the quadrant helps to hold their position.
