WD45 Throttle ????
Jim in Michigan
08-09-2002 16:20:40
I have a Wd45 and the problem I have is with the throttle,, when I set it at full or even half it doesnt stay there,, what keeps it there also the position on the throttle when the engine is wide open is only half way ,,,how do I adjust this? ...Thanks....Jim
Jim in Michigan
08-11-2002 15:49:37
 Re: WD45 Throttle ???? in reply to Jim in Michigan, 08-09-2002 16:20:40
It was a missing spring,, thanks alot,, works like a new tractor now ....I took the spring off the WD took less then 3 minutes to fix,,,now i know why this board is so good lol....JIm
Jim in Michigan
08-11-2002 11:20:48
Thanks guys,,,I have a WD tractor that I am working on as well,it has a bad engine, needs a complete rebuild,,I will steal the spring from there if I need one,,Thanks again,,,Jim
JMS/MN
08-10-2002 17:23:52
Follow the throttle shaft down to below the gas tank and you will find a half-moon shaped device, then later a pivot and a swivel with a set screw holding the rod that goes to the governor. Loosen the set screw and adjust the rod into the proper position. Full speed of the engine is slightly less than full travel on the quadrant by the steering wheel. As to maintaining position, are the hard rubber blocks still on your levers for hydraulic and speed control? Their resistance against the quadrant helps to hold their position.
Mark/Ks
08-10-2002 17:23:22
Sounds like a broken or missing compensating spring. Mine fell of some time ago, and would not stay at the set speed. The spring is located down under the gas tank on the right hand side. I got a replacement from the local AGCO, but was pricy at $26. Easy fix...
JMS?MN
08-10-2002 17:27:19
 Re: Re: WD45 Throttle ???? in reply to Mark/Ks, 08-10-2002 17:23:22
Guess we posted about the same time. As I punched in "submit", I remembered the spring you mentioned, and I'm surprised at the price. Makes those parts tractors more valuable.
