Company Logo (800) 853-2651 Shop Now
Re: allis chalmers B or C
Denny
08-09-2002 06:16:46
Primarily width and length. Tires and engine are pretty much the same as it the transmission. Weight would obviously be different as well. The C is the larger in dimension and rarely came with a wide front. The B is the smaller and rarely came with a narrow front (possibly never).
steve
08-09-2002 18:46:11
 Re: Re: allis chalmers B or C in reply to Denny, 08-09-2002 06:16:46
the C rear wheels are mounted with 5 lug nuts.
the B rear wheels slide on a tapered shaft with one large lock nut.
B steering box arm points straight down.
C steering box arm points straight up.
B front axle steering arm is on the left wheel kink pin.
C front axle steering arm is under the left edge of radiator.
C rear axle is 12 inches wider than the B, end to end.
