Allis chalmers B or C
pete
08-09-2002 06:07:20
what is the difference between a B and a C . i have seen many variations of front and rear options
Leroy
08-11-2002 06:25:13
 Re: allis chalmers B or C in reply to pete, 08-09-2002 06:07:20
B a 1 row cultivating tractor, C a 2 row
Phil Munson
08-10-2002 09:30:45
Bs are narrower than Cs. Later Bs and Cs shared the five bolt rear wheel hub connection. All Bs came from the factory with either an arched fixed front axle, or the later series with the optional adjustable wide front. Most Cs were tricycle fronts but some had the adjustable wfe. The steering pitman arm was UP on Cs and DOWN on Bs. Later Bs had the same engine as the Cs Both had the same three speed transmission.
Greg Ballantyne
08-09-2002 22:13:15
In addition the B came with "wishbone" wide front axle or adjustable. The C came with tricycle front or wide adjustable. The C had governor & cylinder differences that yield higher horsepower.
Denny
08-09-2002 06:16:46
Primarily width and length. Tires and engine are pretty much the same as it the transmission. Weight would obviously be different as well. The C is the larger in dimension and rarely came with a wide front. The B is the smaller and rarely came with a narrow front (possibly never).
steve
08-09-2002 18:46:11
 Re: Re: allis chalmers B or C in reply to Denny, 08-09-2002 06:16:46
the C rear wheels are mounted with 5 lug nuts.
the B rear wheels slide on a tapered shaft with one large lock nut.
B steering box arm points straight down.
C steering box arm points straight up.
B front axle steering arm is on the left wheel kink pin.
C front axle steering arm is under the left edge of radiator.
C rear axle is 12 inches wider than the B, end to end.
