Re: Another question about WD steering u joint
Mark/Ks
07-29-2002 05:46:54
Jim is correct, Should be no slop whatsoever!!
I've got my u-joint out now. I took the steering shaft to the machine shop to have the hole where the pin runs through and have them fill and recut.
Also, will have them 'build up' the worn part of the shaft where the supports ride, along with a new bushing in the support by the steering wheel. The u-joint I plan to 'Rebuild' rather than buy a new one. Over on the Allis board, I found somebody before went to Napa and ordered Precision #861. This is a rebuild kit for some kind of PTO. I will pick it up tonight after work and hopefully by this time tomorrow, mine will be as good as new..
