Another question about WD steering u joint
Mac(TX)
07-28-2002 13:33:41
Is the shaft from the steering wheel to the u joint suppose to turn in the u joint by a few degrees when rocking the steering wheel either way?
It does on mine and after removing the pin I found the hole in the shaft to be elongated and the pin is oval shaped in the middle. The pin looks like it was made that way.
My question: Is this proper or should the shaft be tight in the u joint. Should there be some "slop" or "give" in the steering linkage?
Thanks Mac(TX)
Mac(TX)
07-29-2002 20:08:44
 Re: Another question about WD steering u joint in reply to Mac(TX), 07-28-2002 13:33:41
Thanks guys thats what I needed to Know.
Mac(TX)
Mark/Ks
07-29-2002 05:46:54
Jim is correct, Should be no slop whatsoever!!
I've got my u-joint out now. I took the steering shaft to the machine shop to have the hole where the pin runs through and have them fill and recut.
Also, will have them 'build up' the worn part of the shaft where the supports ride, along with a new bushing in the support by the steering wheel. The u-joint I plan to 'Rebuild' rather than buy a new one. Over on the Allis board, I found somebody before went to Napa and ordered Precision #861. This is a rebuild kit for some kind of PTO. I will pick it up tonight after work and hopefully by this time tomorrow, mine will be as good as new..
Jim
07-28-2002 14:46:35
Mac, no slop. All parta should fit tight. Jim
