Re: B missing
steve
07-28-2002 18:40:12
sounds like the gas tank is dirty and plugging up the jet in the carburetor bowl. if it was electrical or valves, you would not get power back by pulling the throttle open. i would clean the sediment bowl, clean the carb jet, and maybe flush the gas tank. if it was heat breaking down the coil you will loose power as the spark drops out. if it comes back when cool, this is a common problem. giving it more gas normally will not help. tight valve lash can also cause a problem. as the valves heat up and stretch, the clearance is reduced and the valves stay cracked open cutting the compression too low. a good idea to remove the valve cover and chekc the clearances, but normally giving it more gas will not make the motor run better.
