Company Logo (800) 853-2651 Shop Now
Re: WD45, help me fix my oil leak please.
JMS/MN
07-27-2002 22:21:37
The leak could be from the rear oil pan seal- as Jim in Michigan says- or it could be the rear main seal, on the crankshaft, leaking into the clutch assembly, and then down onto the floor. That is an engine removal job. Then the clutch linings should be inspected- if worn 1/2 or more towards the rivet heads that hold it (compare to new linings) replace them now- very cheap fix compared to doing it by itself later.
