Re: Wont start
steve
07-21-2002 19:03:59
it probably has a magneto? if so, make sure the small wire on it is not grounded, that is the kill wire. Pull a plug and put in the spark plug wire. ground the plug. crank it over and look for a spark? o.k. this far. if you have spark check the timing, if no spark , chekc the mag point and coil.
