Company Logo (800) 853-2651 Shop Now
Wont start
Sheila
07-21-2002 14:57:24
Help divorced lady here trying to prove to the would I can do it. 50 yr old now les trying. Got my grandfathers 1950 WD I ran as a child. Rebuildig, put rings and bearings in nothtig else just rod bearings
Wont start did nothing with with timing or anything else. HELP
steve
07-21-2002 19:03:59
 Re: Wont start in reply to Sheila, 07-21-2002 14:57:24
it probably has a magneto? if so, make sure the small wire on it is not grounded, that is the kill wire. Pull a plug and put in the spark plug wire. ground the plug. crank it over and look for a spark? o.k. this far. if you have spark check the timing, if no spark , chekc the mag point and coil.
Doug in OR
07-21-2002 17:14:03
Well... what things did you undo? If you pulled the head, you certainly removed the spark plug wires. Double-check and be sure you have the number 1 wire from the distributor going to the number 1 plug. Then rotate around the distributor.. firing order is 1-2-4-3. Set the engine to where number 1 cylinder is at combustion TDC and see that the distributor rotor is pointed at the wire that goes to your number 1 spark plug. Are you getting spark? Is there fuel in the carb? Did you unhook any wires at all? Check the above, if you can't find anything wrong, repost here, describing exactly how you dismantled the engine when you did the rings.
Sheila
07-22-2002 17:25:11
 Re: Re: Wont start in reply to Doug in OR, 07-21-2002 17:14:03
Thanks for all the help and replies. After putting rod bearing and rings in, new head gasket changed the valve settings. Set the valves at 0.10 starts and runs great.
Doug in OR
07-22-2002 18:49:06
 Re: Re: Re: Wont start in reply to Sheila, 07-22-2002 17:25:11
So tell us, Sheila.. what was the problem? Inquiring minds like to learn from other people's ... errr.. adventures.
Today's Featured Article - Identifying Tractor Smells - by Curtis Von Fange. We are continuing our series on learning to talk the language of our tractor. Since we can’t actually talk to our tractors, though some of the older sect of farmers might disagree, we use our five physical senses to observe and construe what our iron age friends are trying to tell us. We have already talked about some of the colors the unit might leave as clues to its well-being. Now we are going to use our noses to diagnose particular smells. ELECTRICAL SMELLS ... [Read Article]
Latest Ad: JD factory 3pt hitch fits 2 cyl 20 and 30 series tractor and 2 JD rear wts for late 2cyl and new gen Price 2000 for pkg calls only [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
