Re: Difficult Shifting
ACORANGE
07-14-2002 09:36:05
TRY SHIFTING WITH THE HAND CLUTCH ,AND IF YOUR MOWER IS TURNING THE TRANS. WILL SHIFT HARD. ALSO I HAVE FOUND WITH MY WD IF YOUR TRANS. OIL IS LOW OR IF YOU ARE USEING THE WRONG WEIGHT LUBE [90WT. INSTEAD OF 140WT.] THE GEARS IN THE TRANS. WILL NOT SLOW DOWN ENOUGH TO LET YOU SHIFT. GOOD LUCK WITH YOUR PROBLEM ...HOPE THIS HELPS
