Re: need help removing sleeves on a d-15
Duey (IA)
07-09-2002 11:24:55
Brian,
An oak block will do fine. Just use a big hammer to knock them loose. NO, do not reuse the O-ring seals. Be sure to clean the block real good and lubricate the lower block, O-ring grooves and O-rings. The sleeves should then just push in with hand pressure. Use a short bolt with a large flat washer between the cylinders to hold them in place while installing the pistons. Duey
