Re: 7050 clutch problem
Craig MO
07-07-2002 19:48:36
Your tractor has a torque limiter which is similar to a clutch but has no throw out bearing. It is released by hyd. oil being diverted to sump and transmission brake. The clutch should release with pedal 2" off floor and depress on down to engage transmission brake. Take left panel off in front of cab and locate the cable that is above power director valve. Adjus cable by sliding in slots until j lever is up against washer on spring on the valve. If cable cannot be adjusted by slots turn end on cable further on and sometimes I have had to cut end of cable and rethread it. This should correct shifting problem unless transmission brake is out or seals are blown on piston but this dosent happen often. Your pulsing you feel should go away when cable gets adjusted. If have other problems hollar back.
Jeremy
07-07-2002 21:06:04
 Re: Re: 7050 clutch problem in reply to Craig MO, 07-07-2002 19:48:36
Hey thanks Craig, I will try that
