Re: model B stalls
markp
06-20-2002 19:56:07
when it starts running rough after it gets hot do you see alot of dark smoke comming out of the muffler. I have a 48 B and it did the same thing.It would cut off after it got hot also and would not crank until it colled off. I pulled each wire off the darn thing but each fired. I chased ghosts on that thing for a solid day until I finally pulled the carb off and found a piece of rust keeping the needle valve open. Before you spend a bunch of money check the needle and seat first. it's cheeper. mark
