Re: 48 AC-B
T.J._N.J.
06-06-2002 07:08:11
I have a worksaver 3 point on one of our c's and we are very happy with it. I haven't tried it on the B yet because the engine isn't finished yet. From past experienc though with B's you can't beat the factory pick up plow's which are still available ocasionally in the classified section on this site. I would try and find a tow behind bush hog to use with your B and you will be much happier with it than a 3 point. All we use the three point for is the post hole digger and the tiller and it works pretty well for that but I dont think I would want to try anything much heavier than that as it gets light in the front end from the tiller when it is raised, I am going to try my mott flail mower on it when I get it back from my brother but I think that might be pushing it on weight. I like the worksaver hitch because it can be removed and installed very quickly and even faster if you put a hydraulic quick connect on the outlet at the pump. T.J.
