48 AC-B
Randall Hawk
06-05-2002 09:42:16
Just bought a 48 AC-B.She runs fair,but I need help with the following: Cranking(will start with starter,but not with hand crank).wires off generator,which one goes where?How are the hydraulics repaired?Itis set up with cultivators, but I want to use it for mowing,plowing,and bush-hogging,as well as other chores.Any help will be greatly appreciated.
T.J._N.J.
06-06-2002 07:08:11
 Re: 48 AC-B in reply to Randall Hawk, 06-05-2002 09:42:16
I have a worksaver 3 point on one of our c's and we are very happy with it. I haven't tried it on the B yet because the engine isn't finished yet. From past experienc though with B's you can't beat the factory pick up plow's which are still available ocasionally in the classified section on this site. I would try and find a tow behind bush hog to use with your B and you will be much happier with it than a 3 point. All we use the three point for is the post hole digger and the tiller and it works pretty well for that but I dont think I would want to try anything much heavier than that as it gets light in the front end from the tiller when it is raised, I am going to try my mott flail mower on it when I get it back from my brother but I think that might be pushing it on weight. I like the worksaver hitch because it can be removed and installed very quickly and even faster if you put a hydraulic quick connect on the outlet at the pump. T.J.
DaveInMI
06-06-2002 04:54:45
I too recently purchased a B. The front seems light going up hill with nothing on it. The 3pt conversions seem to stick out back pretty far. I'm wondering if the front end would stay on the ground. Could any of you guys out there who have been using a 3pt comment?
Greg Ballantyne
06-06-2002 18:29:52
 Re: Re: 48 AC-B in reply to DaveInMI, 06-06-2002 04:54:45
I put a home made 3-point on my B, it hangs out to the rear pretty good. I had some trouble with light front end when implements were on the 3-point, and added frame weights. That helped considerably. You can also add front wheel weights.
steve
06-05-2002 19:37:59
if you have the standard 6 volt battery with the original generator, then the wires go like this.
--"A" or "G" terminal on the gnerator goes to the cutout relay bolted to the generator
--other terminal of the cutout goes to the ampmeter then to the negative battery terminal
--F terminal on the generator goes to the light switch resistor.
--light switch must be grounded to work properly.
--if you want to test charging, short out the "F" terminal on the generator to ground, should get full charge, about 8 amps.
----- -if you have a 12 volt battery, then things have been changed form original.
Randall Hawk
06-09-2002 18:38:19
 Re: Re: 48 AC-B in reply to steve, 06-05-2002 19:37:59
Many thanks for the wiring diagram.Trouble is the cutoff is missing on the generator.Would this come wiyh generator if I had it rebuilt?
markp
06-05-2002 13:20:52
are the cultivators 3 point or belly. Does the lift work at all. is the three point in need of replacing. I have a 48 B that I had to replace the lift on. Mine has a wire that is not connected on somewhere as well but it doesn't effect the running of the tractor.
Randll Hawk
06-06-2002 04:01:14
 Re: Re: 48 AC-B in reply to markp, 06-05-2002 13:20:52
The cultivators are belly type.I am going to have to get a 3 pt.hitch. Is your wire possibly the taillight wire?
markp
06-07-2002 12:53:35
 Re: Re: Re: 48 AC-B in reply to Randll Hawk, 06-06-2002 04:01:14
it could be
Jay C (MO)
06-05-2002 10:22:59
See if this link will answer part of your question.
Randall Hawk
06-09-2002 18:41:15
 Re: Re: 48 AC-B in reply to Jay C (MO), 06-05-2002 10:22:59
Thanks friend,it sure does
