Company Logo (800) 853-2651 Shop Now
Re: Old Allis C????
Bryan Smith
05-28-2002 06:58:06
An Allis C will have a bench seat and will be approximately 45 inches between the rear "drop-down" final drives. An Allis B will also have a bench seat but will be approximately 33 inches between the rear "drop-down" final drives. Both tractors have 3 speed trannys plus reverse. The C is usually narrow front end but could be had with an adjustable wide front. The B was always wide front - either adjustable (like the C) or a fixed arch.
An Allis CA will have a 4 speed tranny plus reverse and a "pan" seat on a shock/spring assembly. If the seat on the tractor is a "pan" seat and is off-center to the right you might have a WC, WD, or WD45.
Carl Ellis
05-28-2002 10:46:27
 Re: Re: Old Allis C???? in reply to Bryan Smith, 05-28-2002 06:58:06
It is a C then. I have a narrow front and a bench seat. 3 speed trans.
Bryan Smith
05-28-2002 11:17:07
 Re: Re: Re: Old Allis C???? in reply to Carl Ellis, 05-28-2002 10:46:27
Nice tractor, Carl. 125 cubic inch engine, 23.3 belt hp on gasoline or 19.4 on tractor fuel (check the engine serial number on the left side flange where it connects to the torque tube - a serial number starting with CE" means 125 cubic inch, one ending with "G" means the higher compression gasoline engine). Rated at 1500 rpm.
Today's Featured Article - Harry Ferguson - The Man & The Machine Harry Ferguson was christened Henry George but every one called him Harry. Harry was born in a small Irish town called Growell in County Down about 16 miles from Belfast. Harry Ferguson led a varied and colorful childhood causing mischief where ever he could. He showed mechanical aptitude at a very early stage in life and showed no inclination towards ... [Read Article]
Latest Ad: Need one ,castiron, screw-on hub cap. for a JI Case 8 foot grain drill [More Ads]
