Re: hd5 crawler, grease track adjustors
steve
05-09-2002 19:20:40
one good check is to remove the grease fitting and then put a 2 x 4 chunk between the track and rear segment. back up a few inches and the wood will get stuck and pull the chain tight, grease should squirt out the filler hole. if it dont, then you have the hole plugged and need to dig deeper into it. also go to www.ibdozing .com , those guys do more "construction equipment" than people on this site.
