Re: CA won't run
Duey (IA)
05-08-2002 18:55:43
Bryan,
Possibly you have 1 or more valves stuck in the open position. To determine this, you have to remove the valve cover to observe the valve operation or you have to perform a compression check. You have to have compression, ignition, and fuel for it to run. If you feel it is getting fuel, then you should check for spark at the plugs. If you have fuel and spark then lack of compression could be the problem. Duey
