Re: CA clutch
Mike R. in N.C.
04-28-2002 16:58:35
I think if you'll look at all the points it pivots on the wear all ads up to not enough throw. I have seen alot of them cut in half and a die run down each end and then a turnbuckle to give more adjustment. I'm not saying it's correct but it works, it's something like that or you will have to weld up the rod where it goes thru the pedal and grind back the right diameter, and the same to the pedal and the rod it pivots on. Hope I've been clear as mud ??? LOL Mike
