Company Logo (800) 853-2651 Shop Now
Re: WD 45 Governor Issues
Duey (IA)
04-26-2002 12:55:14
CC,
You probably need to replace the governor weights and pins. Very little slop in the weight pin hole will cause a sluggish governor. If a weight is broken, be sure to find all of the parts. Broken pieces have a habit of hiding on a ledge behind the cam gear and can cause MAJOR damage when they go through the gears. Leave the distributer in the governor housing. Before you remove the governor housing, mark the exact position of the rotor in the distributer, then when you reinstall the governor housing, you can mesh the governor gear so the rotor is in the same place. Then a recheck of the timing is just a matter of hooking up the timing light. That is IF you didn't turn the engine when it was apart! Duey
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: John Deere Tires And Rims, (1) Set Of Duals, Axle Mounting Hubs, Tire Size 18.4-38, Units Are Off Of A John Deere 4440 Tractor, Year Is Unknown [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
