Re: locks up going forward
Michael Soldan
04-09-2002 19:55:44
Eddie I had a Case do the same thing and it was a bent shifter fork that was trying to slide forward gears into place when the rear gears weren't out. Did you have the shift lever locking , or did you have to give it a wrap to shift? I believe mine got bent by an inexperienced driver who just jammed the shifter into gear and caused the fork to bend and actually crack. I had to take it out and get it welded, aligned the gears and everything has been fine since...about ten years now..good luck from Mike in Exeter Ontario
