Re: STUCK HYDRAULIC LIFT RAMS on WD-45
Jamie
03-17-2002 13:46:23
Try disconecting the lines at the lift cylinder to see if that brings them down. Do with extreme caution and be out of the way. Fluid in lines are under pressure be careful and take your time. If this brings the rams down than the rams are not stuck and problem is in the hydralic pump. I had problem with my WD with the loader (rear lift rams disconnected) would rise but not go down. Ended up being the valve assembly in pump was stuck in the lift position.
