Re: D 17 series 3 allis chalmers tractor
JMS/MN
03-05-2002 21:04:07
The tractor needs to be split in order to replace the discs on the hand clutch. If memory serves me correct, there are shims that can be used to adjust the clutch- maybe that's all it needs. You can drain the oil and remove the cover on the right side and check the adjustment. Move the operating lever into low range and you will see which clutch pack is engaged. If you split the tractor, buy, rent, or build an adequate splitting frame to support the tractor. If wide front, wedge blocks between the front cast housing and axle frame so the front stays upright.
