Re: Allis model C specs ?
steve
02-17-2002 15:04:23
If the paint is auto quality, and tires are new, you could guess $1800-2000. some will ask a little more or less, depends on who is selling and who is buying. New engine, tires and paint add a lot. The tractor weighs about 2500 pounds and has a little over 20 horse power. This is real horse power, or the same you get in a garden tractor. The tractor is a three speed, idles about 500 rpm and has a full throttle of 1600 rpm. It will travel about 7 miles per hour. This is a good tractor with a 6 ft belly mower, 5 or 6 ft rear pull mower, or sickle mower. The hydraulics are low volume, high pressure. It is limited to pull implements due to no 3 point hitch. Makes a good field mower, or hay wagon puller, or parade tractor. This is a "general overview". I rounded off a few numbers to make it easy.
