Re: fork lift on wd45 ?
Ron
02-13-2002 12:45:21
Any WD-45 WORKING--should have the rear wheels LOADED..... If using a manure loader....the rear wheels Must be Loaded, and set as wide as you can... 300, to 400 lbs of wheel weights on each side would be about as good as loading... At the Nebraska tests, they had to add 3,200 lbs to the tractor, to put all the power to the ground..!!! A WD-45 won't pull 4x14" plow without ALL 4 wheels LOADED.... Power-wise...NO Problem....!!
