Fork lift on wd45 ?
bill a
02-13-2002 02:55:07
thinking about builing a fork lift for 45.going to use for lifting wood baskets[firewood cordand 1/2].it dos'nt have to be real heavly built;but wundering how 45 will handle the weight;light on front end.trying to cut down on the heat get out of wood[handling 5or6 times ]getin little older.if any one has any ideas on this would be appreciated. thanks bill
Ron
02-13-2002 12:45:21
 Re: fork lift on wd45 ? in reply to bill a, 02-13-2002 02:55:07
Any WD-45 WORKING--should have the rear wheels LOADED..... If using a manure loader....the rear wheels Must be Loaded, and set as wide as you can... 300, to 400 lbs of wheel weights on each side would be about as good as loading... At the Nebraska tests, they had to add 3,200 lbs to the tractor, to put all the power to the ground..!!! A WD-45 won't pull 4x14" plow without ALL 4 wheels LOADED.... Power-wise...NO Problem....!!
DaveInMI
02-13-2002 03:17:09
AC put them on the back. I've seen both WD and WC tractor-forklifts. They were set up to go big wheels first. I don't like how my nf wd handles a loader for tippy or steering. I'd think a forklift would be worse.
