Hey Duey (IA) @#$%@# D10 still won't crank!!!!!
ShepFL
11-03-2001 08:13:53
This rig is really trying my patience. Thanks to Duey(IA) and our email exchanges I was able to locate a new solenoid. Thanks to Steve and all the others for previous assitance.
Replaced solenoid and this rig still refuses won't crank. Just get a click, click, click. I am suspecting a bad ground between starter and frame as the bolt used to hold starter in position is "wallered" out. Today I am going to try and jump start it across the terminals.
Once I eliminate the suspect starter ground problem any other tips/tricks?
Also, how can I test the Echlin Voltage Regulator as I am sure that will be next!! Looking for the AC tractor gods to smile down on me just a bit before I really get !@#$#!@*
Thanks to all who have helped in the past and continue to do so now. I will keep you posted of progress on getting this rig started and fixing AC single bottom 16" plow beams. Another dumb@ss move with another story.
P*issed at my D10!
Gordon-Tn
11-08-2001 00:38:52
 Re: Hey Duey (IA) @#$%@# D10 still won't crank!!!!! in reply to ShepFL, 11-03-2001 08:13:53
I posted a message that was meant for a followup for you
D10 from Gordon-Tn
Tom from Pa.
11-07-2001 11:06:29
I had this problem once. My good battery wasn't so good.
D13 - why won't it run?
11-05-2001 18:09:22
First things first.
Why won't it run?
Had a similar problem on my Oliver S55, only I didn't get the click. Troubleshoot the running by the following simple procedure.
1. Check for fuel in the bowl. Clean if dirty or milky (water in gas). If you have the fuel bowl off crack the valve for a second and make sure it flows.
2. If you have a timing light hook it to the coil to distributor wire.
3. Hook up you pull starter.
4. Turn the fuel ON (my favorite step to forget). 5. With the ignition switch ON, hold the timing light trigger down and hold the light where you can see it. Try to start the tractor and see if you get flashes.
Flashes? Check the distributor cap/rotor/wires or a fuel problem.
No flashes? 1. With the ignition ON check for battery voltage at the switch side of the coil. If you do not have this, turn the switch OFF, disconnect the coil to distributor wire at the coil, turn the switch ON, and check again.
2. If no voltage, the switch or wires between the battery and the switch and coil are bad. (This is what my Ollie had). Buy a switch and a couple of alligator clips, and make a jumper switch (use #10 wire). Hook the coil up to the battery with the switch, turn it on, and try pull starting again. (Worked on mine. My starter was good so I made a second swithc to jump the starter solenoid. Note this will run down the battery quickly). If it runs rewire / reswitch.
3. If good voltage, points/condensor/coil/coil to distributor wire.
As to your starter problem: This is a trick I learned in auto school many years ago. You need two people and a set of jumper cables. Remove the starter and place on a cement floor. One person holds the starter. Hook one side of jumper cables from battery to starter power terminal, not the solenoid. Then the second person just touches the starter case with the other jumper cable. The starter should spin - hang on because they are very torque-y! (good spark show too)
If it doesn't spin it's a starter issue. The copper contact washer is a good cheap try and has fixed many a Delco product. If it does spin than rehook the cables to the solenoid, and use the switch from above to connect the solenoid battery feed to the trigger solenoid. If it still works cables or solenoid wire. If not, solenoid or the connections. Best of luck.
Dave Grubb
11-05-2001 11:00:50
I don't know if I missed it or not but hook some battery cables directly to the frame of the starter and the power 'in' lug of the starter. The point is to see if the starter will run by itself when hooked up direct. I had a solenoid fail me once. It was mounted with the internal heavy copper washer down. It had become unswagged from the steel slug(armature) of the solenoid. The solenoid would click and sound perfectly normal but the starter would not run. I removed the starter and hooked it up direct and it ran perfectly. I used a test meter on the load side of the solenoid and there was no voltage coming from the main starter lead terminal with the key held in the start position even though the solenoid sounded normal. Remove your solenoid and see if you can get the washer to rattle around. I removed the solenoid I was having trouble with and just happened to hear rattle as I was handling it. A new solenoid cured the problem.
GeneD14
11-05-2001 09:52:32
I had the same problem with a D10 that I reastored last summer. On mine the ignition switch was the culprit. Jump across from the battery side of the switch to the starter side with a short piece of wire to check for this.
ShepFL (11/4/01 9pm update - a long read)
11-04-2001 18:33:41
Alright Y'all -
First of all thanks for the great comments, suggestions & encouragement. I will address each person's response. Still just click, click, click. . . more about that at the end of this post!
AC single bottom 16" plow beams still bent - no progress to report.
Response to Mr. Roger Small
Starter is not stuck in the flywheel. That was one of my first suspicions and reason for pullling starter. Can turn starter bendix by hand. Can also turn motor over - got good oil pressure. See end of this post for R&R of starter. Thanks for your encouragement. :)
Response to Mr. Bruce Nelson
Have not yet looked at this possiblity. At this time there is no tapered bolt installed. I thought I had an intermittent ground because of this bolt. Retapped & installed new untapered bolt = 0 ohms. Got it pushing against the tapered hole. Might have this to tight and your comments warrant additonal investigation. Can starter be in any position that engages the flywheel and be tightened down? See bottom of post for working through the electric problem areas. Any other ideas on WIERD things to look at? Thanks for the encouragement. :)
Response to Mr. Glenn
I think you may have the hit the nail on the head!!! Yes, I have used a meter to check volt drops and am fluent with one. Used to be in aviation until Clinton killed Defense Industry. Plan to follow your sequence of events, BUT, how do I read thru the regulator (no schematic)?
Response to Mr. ShepFL (doh!)
Maintained my composure for the entire day. Fought off the overwhelming urge to try out my new .44 Mag handloads (D10 for sale cheap - BLOWN BLOCK !!) See other comments at the end of this post.
Response to Mr. Gordon of TN
Will be checking for voltage drops and replacing cables, wires as needed. Thanks for the encouragement. :) As to the air - yeah, to much humidity for me. I'm originally a North Idaho hillbilly.
Response to Mr. kb
My starter is the model that has the solenoid mounted on the side of the starter. Jumped the starter off as described. Still click, click, click. Suspect the starter is froze up as you mentioned as new solenoid tested with 3 different power sources (static battery, jump from truck & battery charger).
Response to Mr. Dale E.
Thanks for the kind words and understanding. I have not cleaned the starter contact but I will. Be careful! I have been exercising care. I will be verifying electrical.
Sunday's effort -
Tractor still sitting in the yard, no bullet holes or sledge hammer adjustments YET! Now that I have had a shower and some iced tea the .44 MAG urge is SLOWLY subsiding!!
Recleaned terminals on the regulator - got a new one on order thru NAPA. Supposed to be in by Wednesday.
Swapped out battery with one from the Oliver. Still no joy.
R&R'd starter per Mr. kb, jumped it outside of the tractor using a battery then jumper cables to truck & finally directly off a battery charger with cranking amps. Bendix drive can be manually turned, HOWEVER, it never engages when jump testing. Click, click, click continues. Suspect froze starter. I've had starters go bad and it was always the solenoid. Thinking I should put in new brushes and bushings after electrical is verified 100%
Motor turns over nicely. Have no compression gauge but assume compression is good. Good oil pressure (between O and R on original Allis gauge).
In a fit of frustration I figured that I would pull start the #@!#%^& thing! Had Mrs. ShepFL hook on and drag me and this da&m tractor all over Baker County, FL miles showing all my neighbors the great gas mileage my D10 gets. Tried 4th gear, 3rd gear and finally 2nd gear - choked and unchoked, full throttle, no throttle. TRACTOR REFUSED TO START & STARTER STILL FAILS TO ENGAGE/CRANK.
That said, I feel I have more problems than just a finicky starter - it should have pull started RIGHT???
Action plan for this rig in order of priority -
1. Verify all electrical continuity (including instrument panel).
2. Check for voltage drops.
3. Replace defective wiring as needed.
4. Check coil and distributor for spark.
5. Check plug wires / coil wires.
6. Replace regulator as required. 7. Reclean carb, verify no stuck or sunk float. Considering to send out for rebuild if anyone knows of a good shop in the SE.
8. Remove starter and clean inside & out.
9. Add new starter brushes and bushings.
10. Verify starter coils & armature.
11. Verify internal starter/solenoid ground switch
12. Pray the generator is good.
13. Try to start again with key, barring that try pull starting again.
14. If still no joy (click, click, etc.) verify .44 MAG stash
15. Determine long & short range handload efficiency
16. Post YMTAG Tractor 4 Sale ad - D10 with blown block!!
Thanks again y'all for the time & consideration. Stay tuned. ShepFL
roger small
11-04-2001 16:20:35
Sounds to me like your starter is stuck in the flywheel. Put the tractor in high gear and rock it backand forth. Be smart or cooled off enough not to have the key on!!If you don't get good results, take the starter off,ground it and trythe start switch. Good luck!!
Bruce Nelson
11-04-2001 06:59:21
I had something similar once. After working through the electric problem areas, one of my customers, absolutely could not get his tractor to turn over. I went out to his farm & discovered the starter had been in & out so many times that the tapered bolt that holds the starter in had worn itself down. This allowed the tip of the bolt to slightly pass through the starter housing & contact the starter drive. This locked up the starter so tight, no battery or cables would make it spin. Worth a look, it doesn't take much wear on the bolt or in the starter hole to do this. Sometimes when stumped, the weird things are worth a look. Good luck
Glenn
11-04-2001 06:36:18
Have you ever used a volt meter to check volt drops? Set your meter on scale as close to 14 as you can (usually 0-20) put one lead on the neg battery post and the other on the engine block, try to crank tractor and observe reading on meter. If it is .5v or less congratulations you have a good ground circuit. If it is above that then you need to chk drop on each individual component until you find the high volt drop and fix it.
ShepFL (UPDATE - click, click, click continues)
11-03-2001 15:16:34
Well, p!ssed away half the day trying to get this thing started.
Retapped 5/8" hole on frame where starter mounts & added new bolt to position starter.
Measured 0 ohms between starter case, tractor frame and newly installed bolt. To me this eliminates suspect ground issue.
Jumped solenoid from known good battery, still just get click, click, click.
Removed Echlin Voltage Regulator, cleaned terminals, added new ends to the wires and reinstalled - click, click, click.
Removed voltage regulator and opened up. Looks brand new inside. Planning to replace this next.
Looking for other suggestions. Thanks.
Gordon-Tn
11-04-2001 01:19:20
 Re: Re: Hey Duey (IA) @#$%@# D10 still won't crank!!!!! in reply to ShepFL (UPDATE - click, click, click continues), 11-03-2001 15:16:34
I had this problem several times when I spent the winter in Fl working at A packing house doing maintenance. Turned out to be coroded cable not supplying enough curent, something in the air I guess
good luck Gordon
kb
11-03-2001 16:58:45
Does that model have the solenoid mounted on the side of the starter like a Delco, or is the solenoid mounted off the starter?
With the starter off the tractor connect the positive side of the battery (assuming it is 12volt negative ground) to the big lug on the solenoid and connect the ground to the starter at the point you ran the big bolt through the starter at, as the metal should be cleaner and give your a better ground. Cross the big lug and the smaller and see if it will turn the starter without the extra stress of starting turning the flywheel.
If it is possible to access the copper connection point between the solenoid and the starter you can connect the positive cable at that point. The starter should easily turn at that point, assuming it is not froze up.
I've had starters go bad and not turn, after putting in new brushes and bushings it worked fine. Bushings and brushes just cost a couple of dollars to fix it with, if they are the problem.
The click you are hearing is likely the solenoid engaging, but the starter is failing to turn. A low battery can also cause this to happen.
Dale E.
11-03-2001 16:46:45
Shep, Understand your frustration well. There should be a contact on the starter somewhere that needs and should get all the juice it can get from the battery. Find this contact, clean it with some fine sand paper or a file until bright and shiney.If you can hook your jumper cables to this post(or contact)put the positive cable lead to it and the other positive lead to the positive post on the known good battery and then hook (-) battery cable to the (-) terminal on the known good battery and with tractor in nuetral and with kill switch on kill, place other end of (-) cable to the new and clean starter ground bolt and you will either get some action from the starter or the starter is bad( or needs help) or your jumper cables are bad and/or you battery is bad. It might be better to touch the contact on the starter last on second thought. If the engine turns over, work backwards through the system to find your problem. (battery cables may look good but may not be able to handle the cranking amps needed. Be careful! HTH
