Re: old D14,,she is running, but not well
Steve Carmack
08-02-2000 11:34:35
After you have replaced the plugs, if it's still running rough, take a look at the plug wires. If you can have your tractor in a completely dark place or near to it, start it up and look at the wires. If they are badly deteriorated you should be able to see fire jumping from wire to wire or to nearby metal. Also look at the distributor cap at the same time. If it has cracks or bad places, you might see fire jump there. Same thing for the coil.
