Re: WD 45
Brian G.
05-30-2000 06:39:47
Regardless of where #1 "should be" on the distributer cap, I would bring #1 piston up to TDC, remove the distributer cap and see which distibuter cap terminal the rotor is :pointing to". That will be your #1 terminal.
Bob Davis
05-30-2000 21:08:04
 Re: Re: WD 45 in reply to Brian G., 05-30-2000 06:39:47
Make sure it is on the compression stroke. Both valves should be closed. By covering the spark plug hole with your finger turn engine over with hand crank until pressure blws air past your finger then top dead center piston and note rotor location in dist. cap and start that as #1. Then wire your plugs in the correct firing order. Then try to start with the dist. not tightened and rotating as you try to start. You may need to go CW or CCW.
Good Luck
Bob Davis
