Re: WD 45 implements
Russ
03-28-2000 17:46:35
You could pull a chisel with either of the tractors You listed. Most chisel's are designed so that you can take the shanks off. If It won't pull a six shank narrow it down till you can pull it. It can get really time consuming but it can be done. My grandpa used to pull a 3 bottome plow with a 38 wc, but he could only get about 30 acres a day if he started at daylight and ran till dark. good luck
