Re: WD 45 PTO GEAR BOX
Brian G.
03-14-2000 06:43:29
Fred, The P.T.O. shaft will not slide back without removing the 2 bolts that hold the rear bearing carrier to the differential. The bearing is a "press-fit" on the shaft. I never had any problem removing these shafts, but, as Tim says, if it's rusted you may have to resort to penetrating oil and/or heat.
