WD 45 PTO GEAR BOX
FRED PRIEST
03-13-2000 17:04:44
I NEED TIPS FOR PTO GEAR BOX REMOVAL. I CAN'T SEEM TO GET THE PTO SHAFT LOOSE. BOLTS ARE OUT AND BOX IS DROPPED A LITTLE SHOWING ME A BUSTED GEAR. ANY TIPS WOULD BE APPRECIATED. THANKS
Sandy Lake Implement
03-14-2000 19:07:10
 Re: WD 45 PTO GEAR BOX in reply to FRED PRIEST, 03-13-2000 17:04:44
When you surmise the damage contact us about
parts-new or used. e mail or ph 724-376-2489
8-5 EST or 24 hr fax 724-376-3775
Brian G.
03-14-2000 06:43:29
Fred, The P.T.O. shaft will not slide back without removing the 2 bolts that hold the rear bearing carrier to the differential. The bearing is a "press-fit" on the shaft. I never had any problem removing these shafts, but, as Tim says, if it's rusted you may have to resort to penetrating oil and/or heat.
Tim(ny)
03-14-2000 05:15:21
I don't recall having a problem when I removed mine. After you remove the bolt, it should slide off, IF it isn't rusted. Penetrating oil and heat should get that. Good luck.
