Re: wd-45 where did my horse power go?
steeve from mo
02-25-2000 19:19:53
Before you do anything else, check to make sure your spark advance in the distributor is working properly and that your governor is opening up properly. Change plugs also, they're cheap. Any binding or sticking in the advance mechanisms will cause what you describe. Your carburetor icing on the outside doesn't mean much, but you do need to check for leaks between carburetor and manifold and between manifold and block. Also make sure your air cleaner is not plugged or bent causing poor air flow. One guy told of having mud-dauber nests in his (other brand) tractor. that would make it doggy, too.
