Re: Mistakes in WD-45 profile
Dennis (Wi)
02-11-2000 15:08:17
Roger..... I have also noticed this tractor "pictured" being a diesel ,it is rather obvious.I can agree with your concern also.
Aaron
02-12-2000 16:14:03
 Re: Re: Mistakes in WD-45 profile in reply to Dennis (Wi), 02-11-2000 15:08:17
Well, you sure got things fixed quick. The caption confirms that the picture is a diesel, and the story under calls the engine a 4x4.25 Good work and way to stay on your toes.
Aaron
Dr. Snow
02-13-2000 09:09:07
 Re: Re: Re: Mistakes in WD-45 profile in reply to Aaron, 02-12-2000 16:14:03
Interesting fact that the engine is a 4x4. Quote from a tractor calender showing a '38 WC for June 2000. ""The WC was the first in the tractor industry to use the so-called "square" engine - an engine having the same bore and stroke.""
Aaron
02-13-2000 12:35:55
 Re: Re: Re: Re: Mistakes in WD-45 profile in reply to Dr. Snow, 02-13-2000 09:09:07
The WC was the first to use a square engine, with the 4" bore and stroke. The WD used the same engine, but the WD 45 used a 4.5" stroke on the same 4" bore, for the 226 CI vs. the 201 of the WC/WD.
Aaron
