Mistakes in WD-45 profile
Roger
02-11-2000 13:39:17
I don't know if anyone else has noticed or commented on the glaring errors in the profile of the WD-45 that is listed at the bottom of every response page. First it states, just above the tractor picture WD-45 (GAS), but that sure looks like a diesel to me. The short space in front of the radiator as well as the extra filters on the side of the engine, leads me to beleive this is a diesel.
The second error is the statement that the WD-45 has a lot more horse power than the WD due to a larger "bore" and stroke. The WD-45's that I have owned and operated did have a longer stroke, 4 1/2" compared to the 4" stroke of the WD, but the bore of 4" was the same on both tractors. Also according to all the technical books that I own this is correct. This may not seem to important to some but a lot of people depend on this info for their education on old tractors. I don't know who wrote this but I do like to see things correct when so many people are looking.
Roger
Roger
02-13-2000 07:46:11
 Re: Mistakes in WD-45 profile in reply to Roger, 02-11-2000 13:39:17
Thanks for the fix on the WD-45 profile. Hopefuly people won't get confussed or get incorrect info. It is easy to make typo or whatever, just as long as we fix them.
Thanks asgain!
Roger
Kim
02-13-2000 18:24:03
 Re: Re: Mistakes in WD-45 profile in reply to Roger, 02-13-2000 07:46:11
You're welcome, and thanks for pointing it out. We do want to be as accurate as possible... unfortunately I'm only human and try to do too much at a time I guess.
Kim
Dennis (Wi)
02-11-2000 15:08:17
Roger..... I have also noticed this tractor "pictured" being a diesel ,it is rather obvious.I can agree with your concern also.
Aaron
02-12-2000 16:14:03
 Re: Re: Mistakes in WD-45 profile in reply to Dennis (Wi), 02-11-2000 15:08:17
Well, you sure got things fixed quick. The caption confirms that the picture is a diesel, and the story under calls the engine a 4x4.25 Good work and way to stay on your toes.
Aaron
Dr. Snow
02-13-2000 09:09:07
 Re: Re: Re: Mistakes in WD-45 profile in reply to Aaron, 02-12-2000 16:14:03
Interesting fact that the engine is a 4x4. Quote from a tractor calender showing a '38 WC for June 2000. ""The WC was the first in the tractor industry to use the so-called "square" engine - an engine having the same bore and stroke.""
Aaron
02-13-2000 12:35:55
 Re: Re: Re: Re: Mistakes in WD-45 profile in reply to Dr. Snow, 02-13-2000 09:09:07
The WC was the first to use a square engine, with the 4" bore and stroke. The WD used the same engine, but the WD 45 used a 4.5" stroke on the same 4" bore, for the 226 CI vs. the 201 of the WC/WD.
Aaron
