Re: Allis CA
Brian
01-30-2000 01:12:26
Its possible the manifold may have cracked. Try spraying a little carb cleaner around the manifold and where it seals to the head and carb while its running. It will pick up a bit if there is a leak. If it is leaking, it will not straighten out no matter what you do to the carb or ignition. Brian
