Posted by Keddano on August 23, 2013 at 12:45:31 from (192.43.65.245):
Figure I'd add a update for anyone else needing advise on adjusting them. Remove the 4 bolts on the cover after unhooking the brake adjuster. With cover removed, the Throwout/In Bearing has 1 spring loaded pull pin that allows the hub of it to be screwed in to tighten the pressure plate. When adjusted correctly the handle will snap over center simular to a JD clutch. The friction disk is a solid sorta bakelite plastic and should last forever if not broken. I"ll be posting a video of the adjustment when I find time under the same user name.
Today's Featured Article - Product Review: Electronic Ignition - by Staff. Oil, for example has come a long way in the last 50 years and I don't use anything but the latest API grade available. I've heard the arguments for non-detergent oils but would never trade it for today's formulations. Paint is another, the modern acrylic enamels are great for resistance to grease and fuel stains, retaining their shine and they last forever; unlike enamels and lacquers . Still another is the alternator. No doubt using the original generator keeps the tractor pure, but for thos
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
