Figure I'd add a update for anyone else needing advise on adjusting them. Remove the 4 bolts on the cover after unhooking the brake adjuster. With cover removed, the Throwout/In Bearing has 1 spring loaded pull pin that allows the hub of it to be screwed in to tighten the pressure plate. When adjusted correctly the handle will snap over center simular to a JD clutch. The friction disk is a solid sorta bakelite plastic and should last forever if not broken. I"ll be posting a video of the adjustment when I find time under the same user name.
Untitled URL Link
Untitled URL Link
