Posted by Davidrz on August 12, 2013 at 11:33:50 from (216.183.60.107):
Working on final steps to put a 1979 Cub to work. While I have the IH50 shop manual, it is not very clear how to check the fluid level for the trans. and diff. OR what type of gear fluid to use.
Questions - how do I check fluid level? Is this fluid for both the tran. and diff.?? What type of fluid (gear oil) should I use?
Today's Featured Article - My Ford Golden Jubilee - by Troy Estes. This article is about my '53 Ford Jubilee and a story that starts with taking the tractor to my brother's Starter/Alternator Rebuilding shop for a wiring fix. The generator was shot as well as all the wiring. I dropped off the tractor expecting a transformation from a 6 volt to a 12 volt system utilizing the original generator housing, and a total rewiring of the whole tractor. The front end center pin bushing was worn also so I ask that they replace it if they had time. Well, that’s wha
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
