The full plug is on the left side of the transmission.
The transmission takes either 80/90/140 wt, or you can use Hy-Tran if you wish. The transmission shares oil with the differential. Capacity is 3 1/2 pints.
The finals have their own oil, and the fill plug is on the inside of them. They are a bit messy to change the oil in them due to no drain, you just have to drop the pans, clean them out and reinstall.
Today's Featured Article - Restoration Story: 1964 JD 2010 Dsl - Part 2 - by Jim Nielsen. Despite having to disassemble the majority of my John Deere 2010's diesel engine, I was still hopeful I could leave the engine-complete with crankshaft and camshaft-in the tractor. This would make the whole engine rebuild job much easier-and much less expensive! I soon found however, that the #4 conrod bearing had disintegrated, taking with it chunks of the crankshaft journal. As a resul
... [Read Article]
