Posted by Janicholson on January 30, 2013 at 21:30:50 from (74.60.94.18):
In Reply to: Farmall H posted by dcfarmall on January 30, 2013 at 19:13:58:
If your bearings were clearanced, it should hold 25 plus at idle. The pumps can wear (usually gear wear into the end plate. it can be ground flat, and clearanced to .001 to .0005". The cam bearings could need attention, were they replaced? Ga;;ery plug leaks are also possible if it was boiled out. The last thing on my list would be weight of oil I would use an oil like 20 - 50 Kendahl, or Other racing oil. Jim
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
