Yesterday's Tractor Co. Same-Day Parts Shipping Available
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Farmall H
[Return to Forum]
dcfarmall
01-30-2013 19:13:58
24.154.234.64
Built stroked H motor, runs good but only has 25lb oil pressure when cold,.. when warmed up goes to about 5 when idling. It does go to 20 when u rev it up. Could this just be weak pump or something else I should look into? Thanks
[Reply]   [No Email]
dcfarmall
01-31-2013 18:25:21
24.154.234.64
Re: Farmall H in reply to dcfarmall, 01-30-2013 19:13:58
Didn't clearance bearings, just got new ones for the tractor and installed them. Took pump apart and sanded wear off plate. It carries 50lb pressure when first started then drops off after time. Has new cam bearings in it too. Got 30 weight oil in it to break in motor. Thinking of running synthetic oil or 15-40 oil, haven't decided on it yet. Thanks
  [Reply]  [No Email]
Janicholson
01-31-2013 18:34:37
74.60.94.18
Re: Farmall H in reply to dcfarmall, 01-31-2013 18:25:21
The stroker crank had to be welded up on an eccentric, then ground round at a greater stroke. My best guess is the diameter might need to be checked with Plastigauge. With the pump serviced, the only things left are the relief valve in the pump, and the bearings in the lower end. Both require removal of the pan to assess. For new it is way low. Did you check the accuracy of the gauge? Jim
  [Reply]  [No Email]
Janicholson
01-30-2013 21:30:50
74.60.94.18
If your bearings were clearanced, it should hold 25 plus at idle. The pumps can wear (usually gear wear into the end plate. it can be ground flat, and clearanced to .001 to .0005". The cam bearings could need attention, were they replaced? Ga;;ery plug leaks are also possible if it was boiled out.
The last thing on my list would be weight of oil I would use an oil like 20 - 50 Kendahl, or Other racing oil. Jim
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
