Farmall Tractors Discussion Board
Re: Farmall A tranny seal
Posted by Dick DeYoung on January 03, 1999 at 19:01:25:
In Reply to: Farmall A tranny seal posted by Brian on January 03, 1999 at 09:03:45:
Once you have it split to replace the clutch, you will need to remove the pedal shaft to split the housing away from the transmission. Need to be pretty careful about this so as not to break the housing casing where the shaft comes through. My pedals were a real bear to get off because of all the rust and shaft distortions (from set screws). Once inside, the seal is pressed in a pretty fragile diecast housing that is bolted to the transmission. There are often as many leaks around the OD of the seal and between the casting and the transmission as through the seal lip.
Good luck.
Dick D.
Post a Followup
: Re: Re: Farmall A tranny seal
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
