Farmall Tractors Discussion Board |
Re: Re: 350 Utility
Posted by big fred on October 09, 1999 at 00:24:55 from (199.238.169.72):
In Reply to: Re: 350 Utility posted by MrG: Thanks Guys! on October 08, 1999 at 23:13:33:
New tires? Nice. You can tell if the PTO is live by engaging it (depress the clutch first, then engage, if you aren't sure which type it is) then depress the clutch. If the PTO stops, you have a "non-live", or transmission-driven PTO. If it keeps turning regardless of the clutch, you have a "live" or "independent" PTO. That's assuming everything is in working order and the seasonal disconnect sleeve is engaged. The manual will explain about the seasonal disconnect, assuming you are getting a manual. In short, it is a coupling sleeve that can be used to disable the PTO when it is not needed or not desired, such as if the tractor is going to be used for loader work exclusively.
Post a Followup
