Re: Front end rebuild on an H... Help...
Posted by Bob M on August 23, 2002 at 07:59:08 from (165.170.128.68):
In Reply to: Front end rebuild on an H... Help... posted by Slappy on August 23, 2002 at 05:54:22:
Hey Slappy - That amount of play in the lower bushing is NG - there should be NO radial play in either bolster shaft bushing. So either the lower bushing shell or the bolster journal surface is severely worn. If it's the shell, simply replacing the shell will eliminate the play. Otherwise you will need to replace the entire pivot shaft. Getting that old bushing shell out in one piece is tough. When I rebuilt the front end on my Super H I wound up using a chisel to cut the shell lengthwise, then collapsing it to get it out. Before installing the new bushing, I first thoroughly cleaned the inside of the bushing bore in the casting. I then checked the bore for burrs, then give it a light coat of grease. To install the bushing I turned scrap of oak in a lathe to make a stepped bushing "pusher". The bushing was then driven into place by tapping lightly with a hammer. As for the bushing lube hole alignment, simply line the hole up carefully with the lube port in the casting before driving the bushing into place. But if the hole doesn't line up when you are finished, you can remove the grease fitting and drill a new lube hole in the bushing using a long bit thru the grease port. A couple more tips: 1 - On my SH I found the upper pivot shaft bushing surface was worn a few thousandths undersize causing a bit radial play at the upper end. So I inserted some thin (.003"?) shim stock between the bushing shell and it's bore before driving the new bushing in close up the space. I also positioned the shim to move the sector gear closer to the worm to help reduce the worm/sector backlash. 2 - A couple weeks after I finished with my SH I found the upper pivot shaft oil seal had a slow, weeping type leak even though the seal was new. So I removed the 90W gear oil, then packed the steering gear box with EP grease. The grease lubes the steering gears just fine and in a year of service still hasn't leaked a bit thru the seal. So next time I do one I'll simply use EP grease instead of gear oil in the steering pot. Hope this helps....
Home
| Forums
Today's Featured Article -
Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
