Farmall Tractors Discussion Board |
Re: Re: Re: 400, 450, 560 Diesels Any knowledge??
Posted by Ronnie on June 12, 1999 at 20:51:56 from (208.30.92.134):
In Reply to: Re: Re: 400, 450, 560 Diesels Any knowledge?? posted by Todd on June 12, 1999 at 09:11:14:
The lift kit might be to keep the tractor level because of the 18.4x38 tires on rear. Parts are high and hard to find for the engine. Just a few things to check to see if it still cheap. Does it start easy on gas and then run without adjusting the choke alot and run fast on gas? If not it might be getting low on compression. When you switch to diesel does it hit on all four right away, and run without smoking? If not injectors might need to be rebuilt. Check the injection pump to see if it is full of diesel, it should have oil in it. The TA how the low side? That's the high dollar side. If all the above is bad it's not cheap.
Post a Followup
